dizzy question on the 22r
Discussion in 'Interior/Electronics' started by Salts, Jul 27, 2017.
  1. Salts
    Salts Newbie
    not sure if this should be in the engine catg or here..any way is there a diagram or or can some explain to me the working of the signal from the key to the coil on to dizzy for the 22r, im asking as i plan to swap in a 302 engine and plan on using pertronix Ft3 plug and play or similar im hoping it should be just wire in appropriate coil and send it on down to dizzy but i do not know if there is a resistor wire or other that might complicate the install
    thanks for your time
