Distributor cap and rotor question
Discussion in 'Engine/Drivetrain' started by toves75, Jun 17, 2014.
  1. toves75
    toves75 Newbie
    Hawaii
    94 2wd
    Hi there I'm in the processing of building my 94 22re. The spark plug wire is leaking and cracked. I want to use just the distributor cap, rotor and wires from a carbureted 22r truck for now. Do you guys know it will work. also it is for a future build going with side drafts and don't want to buy wires twice.
    Thanks Tony.
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Yep, as far as I know, they are identical.
  3. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Yes they will work you will need that dist. and it's vacuum advance for the sides.
