Disc brakes sqeekin something fierce!!!
Discussion in 'Suspension/Chassis' started by Immoreradthanu, Jun 26, 2012.
  1. Immoreradthanu
    Immoreradthanu Enthusiast
    Spokane, WA
    79 long bed
    Hey i just did my brakes a few weeks ago and i went through replaced the calipers rotors pads and the bearings and rear bearing seal. For some reason after about 15 min of drive time the brakes start squeeking real bad(i'm talking ear piercing) anyone had this problem or know how to rectify it? My buddy is a mechanic but getting ahold of him outside of work to help me is a real pita!
  2. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    Did you lube the back of the pad's?Are the warning sensor's in the right postion?It could be a couple thing's that can cause this problem
  3. Immoreradthanu
    Spokane, WA
    79 long bed
    Yeah i was thinkin i need to lube the pads but i don't see why they would make them squeek like that? I guess the piston on the caliper is metal so it the pads are moving a bit. I guess that makes sense.
