diesel swap
Discussion in 'Engine/Drivetrain' started by 73TRD, Mar 10, 2010.
  1. 73TRD
    73TRD Veteran
    Redding, CA
    84 sr5 standard cab short bed, 73 hilux short bed
    i'm thinking about doing this swap to my 84. my buddy has a td mkI jetta and it gets almost 50 mpg hiway. what do you think?
    vw 1.6 turbo diesel
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    would be interesting...do it
  3. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I thought about doin this aswell
  4. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    VW 1.9 or 4BT
    Both respond much better to mods and actually have some ass to em.
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    The 4bt doesn't have many performance parts for it though an doesn't make alot of power yet the power to weight ratio for tht motor an these trucks it wouldfeel like alot
  6. 73TRD
    73TRD Veteran
    Redding, CA
    i plan on doing this hopefully soon. i know people that will help and i have access to a machine shop and welding shop. i just have to see what i have to do for the dmv
  7. 73TRD
    73TRD Veteran
    Redding, CA
    acme adapters has a complete swap kit for $575 shipped. i guess i better start saving up. still gotta find a motor too
  8. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    let me know how it goes and what kinda numbers you get. and how it is performance wise. ive thought alot about it too.
  9. 73TRD
    73TRD Veteran
    Redding, CA
    im just gonna make it a cruiser. i might hop it up later. all i can do to it though is put a bigger turbo and bigger injectors on. should be an easy swap though
  10. cmcpher
    cmcpher Enthusiast
    Raleigh(ish), NC
    93 Std Cab 2wd
    The 4BT shares some of the same performance tricks., i.e. modding the pump, injectors, etc as its bigger brother the 6B series engine found in the earlier Dodges. Though at a hefty weight of 750 lbs dry....the front of the mini may object without some serious work.
