Dash dimmer help!!!
Discussion in 'Interior/Electronics' started by Valleytoyo94, May 8, 2016.
  1. Valleytoyo94
    Valleytoyo94 Member
    So i have a 1994 toyota pick up 2wd.! Some how my cluster lights are not working and every time i turn the dimmer all the way around the fuse blows out.! Ive try many solutions and researched as well and cant seem to get my dash board lights to work.! Please if any one can help new to the minitruck sight.!
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    turn the dimmer all the way around? Which way? Full brightness or full dim? If its popping fuses at full brightness you have an excessive current draw somewhere which is popping the fuse. Could be short to ground. First thing i would do is check all the bulbs and check for any burned traces on back of the gauge cluster.
  3. toy1368
    toy1368 Newbie
    Had the same problem when a buddy installed a car stereo in my truck. He found this:
    Its fixed.
    Valleytoyo94 likes this.
  4. Valleytoyo94
    Valleytoyo94 Member
    Thanks bro i figured it out.!
  5. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    and it was......
