Cross drilled/Slotted Brake Rotors
Discussion in 'Suspension/Chassis' started by phatmitzu, Jun 25, 2008.
  1. phatmitzu
    phatmitzu Veteran
    SoCal 626
    93 Standard Cab 5spd
  2. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    worthless slotted and crossdrilled rotors don't help street cars, can break easily (esepecially ebay crap), and can't be machined later on. If you need new rotors save for the big brake upgrade or get some decent brand regular rotors.
    also your truck is a half ton
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Wrong,if you use a good grade drilled /slotted rotor ,they won't crack with street use,can be turned when needed,& will reduce heat & gassing,giving better braking!!
  4. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    alright I did some research and I was misinformed......
    I still say save for the big brakes or just get high quality regular rotors.
  5. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    if your going to bother upgrading do a bigger brake kit.
    I still have some adapters left to run wilwood 12.19 rotors, and 4wd 4 piston brake calipers... $75 shipped...
    yes this is a shameless attempt to sell more of my adapters... really just trying to get my investment back... I make less than $10 off a pair....
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    MTB68TOY, haven't had the time to get to the install of your brackets & Wilwood rotors yet,too dam busy with this deck replacement!'Will post ophoto's once started on it!!:cool:
  7. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    MTB I might be picking up a set sometime soon.
  8. phatmitzu
    phatmitzu Veteran
    SoCal 626
    Yeah. I would love to do that, but I am having a hard time finding a set of 4WD 4 piston calipers...
    Can you help?
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Got mine off e-bay, $160 with shipping & core charge,pads from auto supply ,around $45,also got fitting to go from female to female metric.:cool:
  10. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    whats the smallest rim you can run with the bigger brake swap?
    and yes, i know of the other thread about the brake swap but i dont want to look threw it all for just one answer.
  11. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    I believe some guys ran 16inch rims... but am not sure... I know from personal experience 17's are good for sure...
    I got mine for a steal on ebay cause they were sold as t100 calipers which are the same (believe it has to be a 4wd t100 tho...) Ebay is the place to get them cheap... just keep looking and a good deal will show up...
