Corner Lights: Oh Joy
Discussion in 'Exterior/Body' started by IronNam, Sep 28, 2010.
  1. IronNam
    So has anyone put their turning signals into their corner lights?
    on my old 2WD corners, I just drilled a hole and stuck the socket in it.
    I'm thinking about doing the 1157 dual filament mod. 3 wires, one low, one high, dim, bright.
    Anyone find any easier way?
  2. IronNam
  3. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    if you do this are you going to smooth our your bumper where the turn signals went?
  4. IronNam
    most likely going to cut out my own plates and put them in place where it was.
    smoothing is an option :D
  5. joeynational
    PHX,AZ
    91 2WD
    thats what i meant fill the holes...you could probably make some fogs out of them too, not sure if it would look good tho
  6. .deadprez_
    .deadprez_ Member
    Miami fl
    94xcab
  7. IronNam
    the foglights in place of the turnsignals have always been an idea in my head. im not sure what fogs i'd buy though..... wal mart ones? lol rectangles.
    I'll try to be creative, i think i'll just make plates to sit in there.
    or an air duct to my intake :D
    edit:
    finished about an hour ago. took forever to do, rtv is currently curing.
    parking lights are so much brighter than before. 1157>194 bulbs.
    everything works fine!
  8. Dcups
    Dcups Addict
    Seattle
    93 Std Cab chassis/4Runner 2door body
    where are the pics.....
  9. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    iv done this.
    i went to the junk yard and looked around for a while and found that early 90's (i think) accords have push in rubber 194 bulb sockets for there outside turn signals in the front. i grabbed a set of those and then drilled like a 1/2 hole in the pickup corner marker and popped the light in. i will take pics of the sockets and later today if i have time cause right now im going to bed.
  10. IronNam
    Yay condensation like no other.
    Pics don't help, but its pretty bright in the sunlight.
  11. andysmiley17
    andysmiley17 Veteran
    Louisville, Ky
    82 Diesel
    have i told u that i love ur truck? looks awesome man :waytogo:
  12. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Nice job man, looks good and still loving the truck
  13. joeynational
    PHX,AZ
    91 2WD
    do you have any pics of how that tube goes into your intake? thats a good place to pic up some cooler air!:waytogo: i think you could use your turn signal to make it look cleaner.
    just cut out the back attach your hose to it and make a grill out of mesh or something, paint it red to match your bumper and it'll look pretty damn good IMO!!
  14. IronNam
    Thanks gentlemen! You guys provide the motivation for me to go on and on!
    I'd fail you guys if I sold her off.
    I sandwiched the end of the tube between my air intake filter and the fender well! :D
    Option 1- The air duct!
    I'm a little unsure if the turn signal itself would be large enough. I think what i will do is take my sheetmetal, and build a rectangle similar to the turn signals. Then I'll just taper it to size and fit the tube to it. Possibly the best way to do it.
    Option 2- The plate!
    a. Basically take my sheetmetal and cut out a plate to cover each side up, painted red.
    b. Or out of this clear red plexiglass i had somewhere...
    Option 3- The fogs!
    Find some rectangular fog lights! Find some off a 4Runner? WalMart?!
    More ideas would be nice!
  15. tenfourtyeight
    tenfourtyeight Member
    Vista, Ca
    94 single cab; 91 4wd extra cab; 74 Hilux
    Brake cooling ducts.:looney:
  16. IronNam
    I think i'm going to take some metal and weld it onto the existing brake duct plate that's factory :D
  17. Dgerfan55
    lake elsinore CA
    94 pickup
    Yea i would also like to see pics of the tube going to the intake
  18. IronNam
    Forgot to upload these.
    Intake pics... lol cheap bastard i am.
    shoved the camera in here to see where i sandwiched the duct lol
  19. lowest93
    lowest93 Enthusiast
    sac town, cali
    93 toyota standard cab
    this is how i did mine i cut the wires and switched plugs heres a video,
    its kinda a ****ty quality but you can see it
  20. IronNam
    I was considering about doing that.
    maybe stick them turn siggies back in and go sequential.
    i'm happy for now.
