Coolant leak HELP!
Discussion in 'Engine/Drivetrain' started by gilpet79, Dec 15, 2012.
  1. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    So I was filling the coolant up on my truck and it just started running out of the tube underneath the intake.
    Is there a gasket that goes on this tube or is it just the rubber o-ring?
    Both surfaces were clean and free of debris before I put it on but i guess that didnt work good enough.
    I couldnt really get a good picture of it but any help would be apprieciated!
  2. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    underneath the INTAKE? -or the THROTTLE BODY?
    the one under the throttle body is for the IAC (idle air control valve) -u may have to remove the whole throttle body n disassemble the IAC valve and clean out all the passages, and the hoses -as well as where they fit into on the engine.
    or the hose itself may be bad
  3. planemos
    planemos Toyotaholic
    British Columbia
    What tube? The upper rad hose? The thermostat housing?
  4. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    the tube runs to the heater hoses on the firewall but when i pulled it off it looked like the oring was worn out, it was flat and cracked so tomorrow im getting a new one and see if that helps
  5. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    You noticed it was flat and cracked but didn't replace it?! *facepalm* Orings might last 20 years undisturbed they don't go back together like that.
