coolant flush
Discussion in 'Maintenance/Repair' started by jIM!, Oct 16, 2010.
  1. jIM!
    jIM! Member
    CA
    95' standardCab 2wd
    how do i flush out the coolant with all these stuff in the way?
  2. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    just pull the plug, lol.... run it with water and reflush...
  3. jIM!
    jIM! Member
    CA
    95' standardCab 2wd
    the area is block'd off though. the fluid wouldn't be able to run down smoothly into a catch pan..... it would just pour out onto everything
  4. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    well, you wouldnt want to put it back in, run new fluid. if your worried about the evironment.. Idk what to say
  5. DROPT
    DROPT Addict
    Whales Vagina
    i just took my radiator out and unhooked the lower hose going to the radiator. worked fine hardly any mess
  6. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    That plug will get about half of the coolant. If you really wanted to FLUSH the system, and get every bit of scale and coolant out...
    -Go ahead and buy a new t stat and gasket with your new coolant.
    -Drain your coolant and recyle it.
    -Take your T-stat housing off.
    -Remove the rad hoses at one end. Upper and lower.
    -Unhook your heater core hoses at 1 end. both of them.
    -Take a garden hose and blast in every connention you undid. Both into the motor and into the rubber hoses. Using your hand as a "gasket" so all the water goes thru the system.
    -Blast thru the heater core. Youll have to turn the temp controls to hot inside the cab.
    -Just flush lots of water thru everything till it comes out nice and clean. I usually spend about 5-10 min flushing and backflushing each connection.
    -Drain as much water out of the system as you can. Theres a drain on the engine, drivers side, behind and under the exhaust manifold.
    -Tighten everything back up and add your coolant(mixed with DISTILLED water).
    Done! :waytogo:
  7. V8_TITAN
    Tampa Fl
    89 std cab
    they sell this thing at advance, you cut your heater hose and put this "T" in, and it attaches your garden hose so you can just run your motor with the drain plug pulled out and the hose on... I have it on my 92
