coiloversss
Discussion in 'Suspension/Chassis' started by lowplz, Sep 27, 2011.
  1. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    anyone using the qa1 coilovers from a 69 camaro in their mini? if so, is it a direct fit? i need to stiffen up my front suspension ALOT. lmk
  2. planemos
    planemos Toyotaholic
    British Columbia
    Well I know that many Tacomas are using them because they already have an upper coil mount. And I know that the lower holes need to be enlarged slightly to mount them on our lower control arm. The lower control arm holes are identical on the 89-95 2wd and the 95.5-2004 Tacoma 2wd. But the 89-95 trucks don't have an upper spring mount so you would have to fabricate one.
  3. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    dammit. thanks for the info. any other way to stiffen up the front?
  4. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I used a set of sway a way t-bars and that with a bigger sway bar has been great.
  5. Domer
    Domer Member
    San Diego
    1985 Toyota 2wd Turbo Xtra cab
    I put a bigger sway bar out of the 89-95 trucks, and i did use kyb gas a just shocks for a 68 camaro, they are bolt in except the hole on the lower tbar need to be slotted out. its alot stiffer and sticks to the corners..
