if i can find one??? can i have a clutch start cancel button put into my pickup???it's a stanard 93 2wd.so i'm gueessing it will have to come from a sr-5 with a 22re since that's what i have too!!! any help would be great!!! thanks!!!
It would be a sweet install to hook up a fuel cutoff to that or something along those lines and just hide it. Good luck on the search. I know i have one in my truck but its pretty useless to me, im used to just stepping clutch already.
you could just jump the leads on the starter with two wires, run the wires into a cab to a push button..
What I did on mine was, I removed the clutch switch on the pedal, extended the wires to the left of the steering wheel where there is a pop out switch panel. I then mounted the switch with a toggle switch cover, so i press on the switch instead of the pedal. You could just removed the clutch switch & put a toggle switch in place of it. Turn in on & off when you feel like. Hope that helps
you can buy new ones at an auto parts store and their cheep along with fitting in just like the factory one
