clutch problem
Discussion in 'Engine/Drivetrain' started by krazedprof, Jun 16, 2009.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    i have a problem with the clutch on my truck how do you bleed the clutch cause its not grabbing and the pedal feels really soft
  2. MacRib
    MacRib Enthusiast
    San Diego
    90 4runner, 94 standard cab, 90 standard cab STOLEN
    There's a bleeder screw on the slave cylinder. Bleed the line the same way you would the brakes. Pump the pedal to build pressure, hold, loosen bleeder screw to relieve pressure and fluid, tighten screw and release pedal. Repeat until fluid stream is steady and no air is coming out. Reservoir is small so keep an eye on the fluid so you don't run out and suck in air and have to start all over.
