clutch line size
Discussion in 'Engine/Drivetrain' started by yota4life, Apr 9, 2015.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I need to order some tubing to redo my clutch line. What size tubing should I get? Also what size is the flare and thread pitch on the fitting.
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I plumbed my whole wheeler with 1/8" steel line. Its a little smaller than the metric line but I didn't have any leaks. The fittings are 10mmx1.0 and they use a double flare.
    You could make it look a bit trick and make life easy for just a bit more money. Get the correct 10mmx1.0 Japanese to -3an fittings for the master and slave and run a braided line all the way between them with no steel. Speedwaymotors.com carries all that for cheap.
  3. silverblazer50
    silverblazer50 Enthusiast
    Thomasville GA
    1994 reg cab
    I used the an adapters, and a -3 line.
