cluste/Speedo help
Discussion in 'Off Topic' started by yota89, May 18, 2013.
  1. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Hey guys need some help again i have an 89 22re converted
    To carb and i was just wondering if my clusters mph runs by
    a cable or relays...my trans has plugs for connectors but they took
    out the lines and dont know where is at and where do the plug
    in frome tthe trans to ?
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Some 89s got cables and some converted to electronic mph gauge if your looking to find wich one you have you can pop the cluster off look n the back and should see a little nub sticking out for the cable connection ...and or the cable connection on the trans I believe is on the driver side and will be large about size of a half dollar coin ... .is that what your referring to ?
  3. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Ok so i pulled my dash and there was no nob to any cable
    went under to look at my trans and only saw connectors on
    on the trans so im guessing it runs to a relay?
  4. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Yea looks like you have the electronic speedo sense you converted .it isnt working right Ecu no longer hooked up ?
  5. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Yup u are correct any idea wst i can do?
  6. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Not at the moment sense the trans doesn't have the cable hookup .....the short cut I can see at the moment is leaving the ecu hooked up and finding out wich wire feeds the speedometer and going from there ... In the aftermarket area ..gauge area ..But I dunno haven't come across this before if you leave the ecu connected will the speedo work ..? I'm sure you'll have check engine light but that doesn't matter on a carb motor
