Clucth Issues
Discussion in 'Maintenance/Repair' started by Reddawg007, Aug 26, 2008.
  1. Reddawg007
    Reddawg007 Member
    Memphis, Tn
    88 Reg cab 22r
    I'm having some issues with my clutch. In order for me to shift gears I have to pretty much put the clutch to the flloor. See I have pretty big feet and once I get the clutch to the floor I'm almost pressing the brake as well. I'm wondering do I just bleed it like I would brakes. Or is there something else I need to do.
  2. Sam78
    Sam78 Enthusiast
    Oceanside
    78 toyota longbed 5speed 20R
    1st check if you slave cylinder is leaking fluid if it looks fine, try bleeding it. If you still dont have any clutch Its time to replace your clutch.
    let me know if that helps,sam
  3. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    i dont know how common this is in the 85+ trucks but ive seen it twice.
    the clutch pedal bracket cracks or flexes and doesnt give you the full swing of the pedal.
    id check to make sure only the pedal is moving when you step on it.
    seen it on a 89 and a 91
  4. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 Toyota HiLux 4x4 RN101
    also make sure your throw-out fork is on correctly and that the retaining spring/clip is holding the fork on the pivot ball.
  5. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    maybe you have a leak? if not bleed it? if still feels the same or slightly different try adjusting your clutch pedal make sure it is to factory specs on the play.
