Clearance of Steering column and Upper control arm
Discussion in 'Suspension/Chassis' started by Barret S, Dec 9, 2010.
  1. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    Ok, so this may be an odd request. So excuse my newbiness.. I'm working on bagging my 86 Toyota, and it does not lay out yet, but I'm getting pretty close. In the mean time i notice that my upper control arm is getting very close to my steering column, the lower i get the truck. Also I plan on doing a body drop, z-frame, which of course changes the geometry of the fire wall opening for the steering wheel in relation to the steering box.
    So, would anyone with a bagged truck, body dropped, etc, mind sharing some pics of how close it comes to touching, or if some relocation is needed? Also, if anyone has any forewarning advice or input. Thanks!
  2. low_toyota92
    low_toyota92 Enthusiast
    Nashville, N.C.
    92 ex cab
    mine hit th steering shaft.. so i just notched it and welde a piece of pipe in th notch and ground it smooth
  3. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    What is done to yours? static drop? bagged? body drop?
  4. low_toyota92
    Nashville, N.C.
    92 ex cab
    bagged bodied on 20s
  5. NotAvailable
    NotAvailable Addict
    if u have money then buy tubulars. if not notch it. i notched mine also sfbd on 20s
  6. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    can i get some heim joints! or do what they said ^^^^ :)
  7. Toyota530
    Toyota530 Veteran
    94 toy xcab
  8. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    Here is the link to my build thread on SSM General Discussions Forum - Under Construction | Not Forgotten - Page 1. I just thought I would share the link with you and you can copy and save whatever pictures might be helpful to you and then zoon onto them. I did not do the build just my ideas to clear that up. Truck is an 82, is bagged and has a stock floor body drop. Should be pretty close to how you are doing your setup. I hope this helps you out and good luck.
    Share some pics of your build.
  9. NotAvailable
    NotAvailable Addict
    yes bro thats my truck but now im on 20s. got tired of them honda rims. another thing u can do is add a knuckleabove ur A arm and just make a bracket to keep it above ur a arm. idk something like that.
  10. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    ^^ Do you have tubular arms. and what did you do with your steering?
  11. NotAvailable
    NotAvailable Addict
    no i have stocks. i just cut a notch on the top part. it still rubs a little but nothing major. i dnt drive the truck often anymore since i started my career i been busy busy busy with work so thats why i left it. but if not i highly recommend tubulars for better lift and a better look too. as for my steering i didnt do anything. my steering is all new tho i replaced my idler arm steering box refurbished new center link with inner nd outter tie rods and ball joints all around. so my steering has perfect play because you cant have too much play or no play at all. u need play due to the fact itll be too stiff and quick if u didnt have play. i forget what my alignment guy set my play at.
  12. NotAvailable
    NotAvailable Addict
  13. toylowta
    toylowta Enthusiast
    river valley arkansas
    94 single cab
    my yota is bagged on 20s with a Z an i have stock arms on it an didnt have to notch the control arm i also i 2 inch drop spindles on it
  14. IronNam
    holy **** you're a rare occurance.... YOU'RE ASIAN TOO!!
    Never thought I'd know another asian guy with a mini Toy :D
    well, waddup bro.
    back on topic haha
  15. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I have tubular uppers an lowers. Just didn't know if my steering is gonna change. I'm gonna be Z notching it an bodying it this winter sometime
  16. NotAvailable
    NotAvailable Addict
    nam- LOL i havent been on forever bro.
    yyota- yeah with the tubulars your lucky you wont mess up anything and you will have nothing to worry about. my truck has spindles and a Z so ur safe bro good luck with ur project ALOHA
  17. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Hell ya can't wait to tear into it again. How much did you Z it an body it
  18. NotAvailable
    NotAvailable Addict
    its a stock floor with a 2 1/2 inch z i believe
