Cleaning
Discussion in 'Engine/Drivetrain' started by 1lowSr5, Aug 6, 2012.
  1. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Bought my Sr5 about 2 weeks ago now and have been going through it slowly and fixing little Maintainance things. Before I bought it it had a valve cover leak and was fixed but all the old oil that puked out is still all over the engine bay and under the truck. I would like to clean it all up some but not sure where to start and what to use. Was thinking of buying a bunch of cans of engine bright and spraying it all down and hitti g what I can with a pressure washer. Just can't do it in the driveway. If it gets in the street I'm sure I'll get a fine and my neighbors will no longer like me...
    I've seen a few threads of people cleaning engine bays but never how and what they used to do it. Just looking for some guidence on this. :confused: :waytogo:
  2. kingtacoma951
    kingtacoma951 Addict
    CORONA,CALI
    88 SR5 Xtra Cab
    Use degreaser first i use venom....half venom or any kind of degreaser and half water....ur gonna have to wash it multiple times....go to walmart and buy purple power that also works good
  3. craigdbl
    craigdbl Guest
  4. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Might wanna check your local Do it yourself spray and wash I no a few around my town do allow engine cleaning . As far as cleaners there's a bunch out there . Maybe get u a small brush skinny kind for some scrubbing and disturbing the cacked up grease
  5. kingtacoma951
    CORONA,CALI
    88 SR5 Xtra Cab
    Just do it at night hahahaha
  6. 1lowSr5
    1lowSr5 Addict
    In the garage
  7. kingtacoma951
    CORONA,CALI
    88 SR5 Xtra Cab
    Sorry about ur grama an try that awesome stuff works good too...
  8. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    fot the really thich oil build up i use easy off oven cleaner. its pretty strong so you cant leave is soaking too long. just repeat the process and it will work well. do not use on painted areas and use gloves because it also removes fingerprints.
  9. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Do yourself a favor. Go to the doller tree and buy 2 bottles of las totally alsome cleaner/degresser...spray and rise. Works great. This is the site that got me using it. Cheap and easy..
  10. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    QFMFT:waytogo:
  11. 1lowSr5
    1lowSr5 Addict
    In the garage
    Sounds like its pretty unanimous...
  12. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    purple power and simple green in a 50/50 mix works pretty damn good too. and you can buy them in gallon size jugs. spray on and let it soak for like 5 minutes then hose off.
  13. Gman
    Gman Member
    Nor-Nev
    78 pickup
    This method works KILLER with your average garden hose and one of those gun nozzle things. You can also run the garden hose off your water heater (easy if in the garage) and hit it with hot water....
