About 5 years ago I started a swap on my 1990 ext cab pickup. Installed a 7MGTE and over the years just lost interest in it. Only need to mount radiator, finish wiring, connect/mount intercooler and run gas line with external fuel pump. Brought a Harley, that's where my interest has been for the last couple years. Now I want to build something to pull my Harley trailer. I'm thinking about taking the 7MGTE out and dropping in a 1UZFE. I have been researching the 1UZFE swap but can not find anything about the engine mounts. Has anyone done this swap? If so can you tell me what is required to install the engine (motor mounts, oil pan, any clearance issues) etc. Thru searching the net I have found that I can indeed use my W58 tranny with the use of an adapter kit. Any information will be greatly appreciated. Thanks in advance.
http://www.toyotaminis.com/forum/build-up-project-threads-19/luxus-2300/ http://www.toyotaminis.com/forum/bu...-23/yotarips-turbo-truck-project-rebirth-724/
I've heard the sc400 is a direct swap mounts and all but not for sure hopefully someone on here can correct me or agree with me
