Changed out the rotors & brake Pads on our 2013 Lexus RX350
Discussion in 'Off Topic' started by TRUCK ACTION, Jun 22, 2018.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    As said above it was time for brake pads & I have found that turning rotors almost always leads to them wrapping. So I changed them out to Power Stop drilled / slotted units along with new pads.
    I've used this brand before on other vehicles with good results.
    54,739 miles on the stock units, the pads were down from 12mm to 4mm at the front & from 10mm to 5mm at the rear! Also painted the calipers at the same time.:cool:
  2. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Agreed. Every set of rotors I've had turned over the years went to warped shit almost immediately. One ended up worse than it started.
