Change pushrod without taking engine out?
Discussion in 'Engine/Drivetrain' started by MeVito, Nov 30, 2015.
  1. MeVito
    MeVito Newbie
    R22-E has one push rod broken, if valve is not bend can pushrod be changed without taking engine apart e.g.
    1. Drain oil
    2. Take head cover off disconnect rod
    3. Drop oil pan and disconnect rod,
    4. Remove rod,
    5. Put new one
    6. Mount valve cover and oil pan
  2. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    There are no pushrods in a 22R. It is Over Head Cam. Perhaps the rocker or the rocker mount is bent?
    Or are you talking about connecting rod?
