Center Drag Link HELP!!
Discussion in 'Suspension/Chassis' started by skahide, Apr 14, 2010.
  1. skahide
    skahide Member
    Im trying to replace my center drag link. I have all the pins out, and all the castle nuts off. For the life of me i cannot get the damn tie rods, steering dampner, and idler arm to come out of the holes. ive hammered the hell out of them. any suggestions?
  2. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    pickle fork!
    ball joint speader or whatever you want to call it...
    it's a 2 prong wedge shaped fork you jam between the ball joint and the "hole"
    They are really effective when used in an air hammer/chisel
    they should have one for an air hammer/chisel at your local auto parts store
    I had one for mine and it popped my linkage right off my steering box
    I am in the middle of change my entire front linkage
    good luck!
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    x2...........
    and when you hit that fork... WHALE ON IT!!! DONT TICKLE IT! :D
  4. planemos
    planemos Toyotaholic
    British Columbia
    The holes are tapered so make sure you are wailing on it in the right direction. It's more work, but I took the whole spindle off and then removed the tie rod ends. It is pretty difficult to swing a hammer up while laying on your back.
  5. jetas
    either pry the crap out of it. Of get an Air hammer. Its wat ima do on my friends '79
  6. NotAvailable
    NotAvailable Addict
    i had this problem..i just replaced the whole steering system n took the tie rod outters off from the spindle but those were stuck also so either way i was screwed..what i did was use a hammer and fork n make it so its nice and tight then grab the SLEDGE HAMMER and wack it the crap out!!!!! and if that doesnt work use acetylene and heat it up alot and then use the fork and wack it.. itll work.
  7. skahide
    skahide Member
    I live in the boonies, so im gonna ask the only local mechanic if i could borrow a fork (if he has it). Otherwise i have to wait a day or so to make a 2 hour, round trip, drive to autozone.
  8. skahide
    skahide Member
    got the center drag link off. have the new one on, EXCEPT the passenger inner tie rod end. When i go to tighten the castle nut, the bolt spins with it. i did bust up the little boot full of grease, not sure if that matters. autozone doesnt seem to carry inner tie rod ends. any ideas?
  9. Toyo Trucker
    Toyo Trucker Addict
    I think you need an impact wrench for this one. I'm having the same issue with my lower driver side ball joint.
  10. skahide
    skahide Member
    GOT IT!!!! Thanks for the help.
  11. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    For next time, Get some PB blaster ( penetrating oil) helps a lot. Glad you got it off. When I did my powersteering changeover and used a few bad choice of words in the process :D
  12. skahide
    skahide Member
    if there is a next time ill try ANYTHING to make it easier. thanks for the advice
