Carb removal help?
Discussion in 'Maintenance/Repair' started by josealex1636, Apr 6, 2012.
  1. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    My question is what the caption says how do I remove my carb from my 83 pickup I want to take it for a rebuild? any help will be great
  2. clark
    clark Member
    Honolulu, HI
    '80 3/4 ton Long Bed 20R
    Remove the Air Filter Housing. Label and Remove the Vacuum Hoses, now may be a good time to replace them if they are Old or Cracked. Disconnect the Throttle Linkage. Unplug any Electrical Wires that are connected (Electric Choke, Fuel Shutoff Solenoid, etc.) Disconnect Coolant Hoses (if equipped with a coolant controlled choke.) Clean the surrounding area, especially right around where the Carburator meets the Intake Manifold. There are Four Bolts holding the Carburetor to the Intake Manifold, unscrew the Nuts that are attached to said Bolts. Making sure that no crud or dirt or anything goes into the Intake Manifold, Remove the Carburator. Plug the Intake Manifold with a Clean Rag so nothing harmful can go inside.
    OR
    Have a mechanic do it.
  3. josealex1636
    Ontario,CA
    83 Toyota Pickup
    Oh alrite thanx man
