I need the gasket that goes between the carb and the intake.What is it called and were can I get it??
You should be able to get one (or order one) from any parts strore.. or buy some gasket material and make one..
I found them on rockauto.I tried gasket material.But I didnt have no luck.It leaked water.I think my material was too thin.But I ordered some from rockauto.thanks for the help tho!!
first there should be an insulator between the carb and the intake. There should be 2 gaskets one on the bottom, intake to insulator one on ''top'', top of insulator to bottom of carb. Carburetor base gasket is the one on the bottom of the carb to insulator Insulator gasket is the one from intake to insulator.
