carb 20r into 86 4x4
Discussion in 'Engine/Drivetrain' started by Comrade_Charlie, May 18, 2010.
  1. Comrade_Charlie
    Comrade_Charlie Veteran
    Rock Hill, SC. Charlotte, NC
    1973 Hilux
    I got a 4x4 from my friend just to resell after I drop my 20r I have into it.
    For some reason someone carb'd the 22re... its blown up now. So I figure if I drop a 20r in it should work fine. The 20r is from a 77 5spd hilux. Will it drop in with no mods?
  2. Comrade_Charlie
    1973 Hilux
    Guess ill find out, doing the swap this weekend.
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    yep drops right in no mods
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    reuse the 4wd motor mounts, unless they look the same as the 2wd ones. I can't remember if the upper metal part above the rubber is the same. Also 22R's came with carbs all the way up to the mid 90s. So it could be stock that way.
  5. Comrade_Charlie
    1973 Hilux
    The valve cover says 22re... I havnt looked for a wiring harness yet, bought it from mechanics that mainly worked on american old v8s, so im sure thats why It went carb...
