found some 20's for 400 bucks and i really dont wanna pass them up. does anyone know about or has put 20's on their toyota pickup (2wd)? i also have a 3/3 drop. any issues with that as well? ill probably do whatever it take to make them fit without too much rubbing goin on. oh and yes i already did the search. didnt find what i needed to know. thanks guys
Well, if you really want them and you are sure the offset and bolt pattern work, then buy them. Mount them. And see where on the inner fenders you need to cut out. Stiff shocks will help. It can be done. But if you want to go lower than you might want to go with full-on tubs for the inner fenders and firewall. It might be kind of hard to figure out without having the tires mounted on the truck. Good luck.
very helpfull thanks, i think ill buy them once i try them on for size, and if they dont make me ride too high.
