cam?
Discussion in 'Engine/Drivetrain' started by -85yota, Jul 16, 2013.
  1. -85yota
    -85yota Member
    im wanting a cam but i dont know what size cam? also what will be needed?
  2. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    what mods do you have and what do you plan on doing to the motor in the future? keeping the head stock or are you going to port it out and run larger valves? what carb do you plan on running? street truck? trail finder? daily driver?
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    There are lots of useage specifics that play a role. Gear ratio, tire size, 2 or 4wd, ect. Also, the carb, ignition and exhaust style you run plays a role. If you're keeping things fairly stock, a mild RV cam should work with stock valves. For a more modded street motor with header, weber, ect; I woul say something about .450 lift would be best. These heads run into valve spring issues about 470 lift, and overall lift issues at about .500" lift. The duration and other cam specs play a role too, but not as much as the lift itself. That sets the whole cam profile.
    Brands like LCE, engnbldr, crower, comp cams, delta cams, Schneider racing and others have 20/22r cams.
  4. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I have a cam for sale coincedentally... lol its a web cam but pretty aggressive. Requires upgraded valve train. thats why I havent used it in mine.
  5. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Also machine shops can get good cams.. And good prices! Just look around and find what's best.
  6. -85yota
    -85yota Member
    i want stock heads for now than i will stroke it or supercharge it with a supercharger somebody was selling on craigslist but i dont know
  7. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    how do you drive the truck? Do you throw it around a lot in high rpm, cruize around in low rpm a lot, want something all-around, race, tow, haul, etc?
  8. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    can you send me the specs on your cam? might be interested in it.
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    If your intended on running a blower . You'll want a cam with a large 112 and higher lobe separation as they are better suited to making the most of a forced air engine as they begin to make power sooner ..tighter lobes aka overlap . Will not make the best use of your boost and are better suited for all motor set ups and or motors utilizing high compression and well flowing head as they are generally upper rpm cams and are doggie at lower rpms do to cylinder pressure bleed off . Like my motor a turd below 3500rpm
    If you do not plan on upgrading valve springs
    There are some small street cams from LC and engnbldr that are suited for stock rpm range and compression . < large factor when considering cams
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    The cam is the heart of any engine, I run the Pro Street version that comes in LC's Pro Street stage 1 engine. Comes alive @ 3,200 , pulls hard from there on up!!:cool:
  11. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
  12. -85yota
    -85yota Member
    when they mean to regrind them do you send out your stock cam?
    street cruise low rpm but i wannt it to pickup fast from a dig
  13. -85yota
    -85yota Member
    whats a good cam without upgrading springs??
  14. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Without breaking the bank any of the engnbldr cams usually around 80 bucks ..
    If you want the low grunt the torquer cam . Has the low rpm range but suffers up top
    The engnblder I think 270 cam s the mid range high range cam with a slight suffer to off idle performance as I've herd this seems to be the preferred one for 2wd
    These cams are regrinds of the oem cam so there really just moving the power around in the rpm operating range .thats why there not as expensive ..but do give a little bump to the 22r
  15. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Valve lift: .475/.475
    Duration: 265*/265*
    Duration @ 0.050" :236*/236*
    Is it too big that it would need valve reliefs cut into the pistons?
  16. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    I would assume not or it would be mentioned on the site. :shrug:
  17. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    No stock un decked head 265 at fifty not to bad . Defiantly wanna run springs .. A bump in compression would help .
  18. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    I assumed the same but can never be too sure.
    Was waiting for you to chime in,lol! I'd be running it on a worked head. And of course, aftermarket valve train
  19. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Yea anything over 280 ish on duration a stock motor won't see any results and will end up being slower . Compression x degreeing the cam are large factors for making any motor benefit from high lift or long or short durations tha aftermarket cams give ... You can stick a big cam in anything and get that cool lumpy idle . But if the motor isn't built for it .. (Your gonna have a bad time )
  20. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Built head, stock block unfortunately for now.
    Ill keep that info in mind when searching for more cams. That's scrub!
