C-Notch frame rails VS. Custom back half
Discussion in 'Suspension/Chassis' started by Shadetree Mechanic, Jul 10, 2009.
  1. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    So I was initially thinking I would fab up a custom back half of my frame when I do the four link, but after talking to some people and thinking on it more I am not sure I should. I am only planning to run 17"s. It might be good to leave room to lay frame with 18"s or so, but still it doesn't seem like it is going to take a huge c notch to get the job done. What do you guys think? Are there any major advantages to doing the custom back half over just notching the frame?
  2. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i would definitely leave room for bigger rims. eventually you'll probably want to go bigger. i built the back half for the hilux simply because i didn't feel like cleaning the surface rust, and cutting off all the old suspension brackets.
  3. Shadetree Mechanic
    Yeah, I guess you are right. I would only have to leave an extra 1.5" to go up to 20"s. Seems worthwhile for sure. Also the suspension brackets are kinda a PITA to cut off. Am I going to have to move my gas tank? That is another factor. It looks like it would be ok if I just raised it an inch as far as clearing the ground, but I think it is in the way of the four link. So if the gas tank mounts and suspension mounts all have to go, I might as well just start with new clean tubing...
  4. burnzya
    bodied 73 hilux
    yeah the tank will need to be moved unless you run a wishbone. i only have a couple hours in design and fab on my backhalf. i would have spent more time removing 36 years of crap of the frame. plus it's a lot cleaner (look wise) than a traditional notch.
  5. Shadetree Mechanic
    Right. I can see that. I was thinking go minimal with the notch because I am only going to run 17"s but I think I would actually kick myself down the road for it. What are the dimensions of the rectangular tube you used?
  6. burnzya
    bodied 73 hilux
    i used 2x3x.120 tube. i'm not going for power of hopping so it works good. a 20' stick only cost me $42. a 8 piece notch cost $80, and that was another reason for the back half.
  7. Shadetree Mechanic
    :eyecrazy:Wow, even more convincing! I am going to go with the custom back half for sure. I have been thinking about it and it just makes more sense. I hate grinding of suspension brackets. It sucks. I think I am going to have the frame rails go up and just stay up all the way back (I think that is what you did on yours too if I remember correctly). Someone was telling me that you can take the take and turn it sideways and mount it between the frame rails in the back. I haven't measured yet to see if it will work but it seems like a pretty easy fix for the gas tank issue. Just extend the wiring and lines. Thats not too bad at all.
  8. burnzya
    bodied 73 hilux
    i'm planning on running a tank from my 86 shortbed. it will fit right between the rails with about an inch on each side.
