C/D does its own Toyota unintended acceleration tests, compares Camry with Infiniti,
Discussion in 'Industry News' started by NewsBot, Jan 6, 2010.
  1. NewsBot
    NewsBot Grand Toyotaholic
    Filed under: Recalls
    By this point, we are all familiar (if not overly familiar) with Toyota's troubles with floor mats, unintended acceleration, biggest-ever recall, etc. And if you're not familiar with Toyota's woes from reading this site, perhaps you've heard about Consumer Reports' investigation into ToMoCo's troubles. Well, guess what? The gang over at Car and Driver decided to launch their own inquisition into FloorMatGate.
    Here's how they set up the tests. C/D took a V6 Camry, a Infiniti G37 Convertible and a supercharged, 540-horsepower Roush Ford Mustang. The Camry is identical very similar to the Lexus ES350 that crashed in San Diego and set off the current brouhaha. Similar in that it has an electronic throttle and push button start. Same brakes, too. The Infiniti also has electronic throttle and push button start, though it's more powerful and has bigger brakes. Also, the Infiniti has a throttle interrupt that cuts fuel when the brake is applied. The Camry - and as far as C/D knows, all Toyota models - does not. As for the Roush, why the hell not? No, actually the reason is to see if a mega-power engine can overwhelm a car's brakes at high speeds.
    Here's the methodology: First they recorded each car's 70-0 mph braking distances with a closed throttle (i.e. foot off the gas). Then they recorded 70-0 mph braking distances with an open throttle (foot on the gas). Next, they upped the ante to 100 mph for both closed and open throttle tests. The results are actually quite interesting, and we will share with you that a Toyota Camry under wide open throttle can stop from 70 mph one foot shorter than a 2010 Ford Taurus under normal braking. Also, it's best to take your foot off the gas in a 540-hp Roush when you're going 100 mph and want to stop. Unless you have 903 feet to spare. Just sayin.'
    [Source: Car and Driver]C/D does its own Toyota unintended acceleration tests, compares Camry with Infiniti, Roush?! originally appeared on Autoblog on Wed, 06 Jan 2010 16:29:00 EST. Please see our terms for use of feeds.
    Permalink | Email this | Comments
    Read More...
