I have bot a 2wd frame nearly rust free (pretty dam rare in Canada.. haah) but i have no idea what year it his , is there any way to find it out? I have to order bushing kit and I want to order the right one hhehe Thanks ohh yeah , i'll start a buildup thread in a couple day! Wizz
can you post a pic of it? the frames where nearly identical between 84-95, with only slight changes in cab mount height, and control arm shape.
Think the easiest tell is the front bumper mounts In 89 the frame added front bumper mounts to the sides of the front body mounts So if the two front body mounts have two bolt holes in their sides??? It's an 89-95
Ok , for sure it's a pre-1989 frame , Now...how to know what year it is between pre-1983 and 1984-1988? I'll post picture in my buildup! http://www.toyotaminis.com/forum/showthread.php?p=85848&posted=1#post85848
the pre-84 frame, both the balljoints point down, on 84+ the upper joint points down, the lower points up. and there are little brackets with 2 holes on top of the front x member. i don't see them on your pics so i'd assume you have an 84-88 frame.
