bumper brakets 84 to convert to 89-94
Discussion in 'Exterior/Body' started by craigdbl, Jul 15, 2011.
  1. craigdbl
    craigdbl Guest
    cando specialities has them for $100--does anyone know where to get them for less?
  2. Dux_Trucks
    Dux_Trucks Enthusiast
    campbell CA
    1988 hi-lux std cab 2wd 5spd short bed
    I made mine using the old brackets some square tubing and a bit of plate .. it only cost me $20 and about 30-60min
    hope this helps a bit and good luck
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Got mine from FBI ,& had to modify.
    If you make yours use 1/4'' plate for the strength to support weight!:cool:
  4. craigdbl
    craigdbl Guest
    cool,that does help,it gives me encouragement to make my own.I hate to waste money on the uncertanty that something won't fit but, when I modify something myself it's more gradifying when it works.
    thanks I'm glad for this forum
  5. garagedoorman
    garagedoorman Addict
    north georgia
    Link to cando brackets plezzz
  6. craigdbl
    craigdbl Guest
  7. garagedoorman
    north georgia
    thanx.
    So do we just drill our own holes
  8. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    I have a "home made" set for sale $40.00 + freight FITS awesome
    if you email me , I will send you a pic
  9. garagedoorman
    north georgia
    email you at the fiberglass link in sig? Yes I'll take the brackets
  10. craigdbl
    craigdbl Guest
    could you post a pic of the brackets? I was going to make my own as well,that way I could see your design. Thanks
  11. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Make your own... Such an easy task and cheap... 1/4' plate is way overkill for a bumper bracket too. Have you looked at the factory ones???
  12. slacker
    slacker Addict
    84-7m-GTE custom
    yep .. [email protected] .. first one gets em ..
    if you want pics .. email me as well .. i used the stock 90'ish brackets with mods
  13. garagedoorman
    north georgia
  14. garagedoorman
    north georgia
  15. slacker
    slacker Addict
    84-7m-GTE custom
    you have an email
  16. craigdbl
    craigdbl Guest
    thanks,I made my own already.
  17. kcernest
    kcernest Newbie
    Pics?
  18. craigdbl
    craigdbl Guest
    [​IMG] I just used this metal and attached it to the stock brackets and bent the outter stock brackets to fit the notche on the bumper and put a bolt thru it. It's on very secure and would protect just as much as the stock bumper if it got hit.[​IMG][​IMG][​IMG]
  19. craigdbl
    craigdbl Guest
