if your truck came with a bench then the inner rail rear bolt is where your seat belts are bolted down now. The bucket seat trucks/runners have the seat belt receivers mounted to the transmission tunnel. You can bolt the seat with the receivers you have now to the same place or get a set of bucket seat belt receivers (which require a bolt welded into the tranny tunnel to mount them) Either way the bolt where the bench seat belt receivers mount is an odd 11x1.25mm bolt... larger than the regular seat rail bolts.... For some reason toyota uses an 11mm bolt on all their seatbelt mounts... (remember this is the actual bolt size not the wrench that fits it size) The seats are bolted in with a 10mm (12mm wrench) All the holes will line up 4runner to pickup.... no drilling required Also on some later pickups the weld nut is missing on the inner rail at the front. You may need to ad a nut, but the hole is there.... (like this on my 93)
i like that idea!! haha or some DEL SOL seats like meee with EG brackets... soo comfortable!! thats the only reason why i took my black gsr leathers out.. it wasnt that comfortable..
ive got the 60/40 split bench and i thought eather put tacoma seats in it or 4 runner seats, maybe even cut out the center area..... but that would be weird to drive around with for a few days..... your reply was very helpfull! thank youuuuu
just an update guys i did a center seat delete, and it looks fine ill post pictures if anyones interested
