brake swap
Discussion in 'Suspension/Chassis' started by boris93, Sep 19, 2010.
  1. boris93
    boris93 Newbie
    ct
    93 strd cab
    imj trying to figure out the biggest and best front brake kit that i can put on my 93 2wd, ive read about supra knukles and lexsus calipers but i can't figur out the best choice. any help please
  2. planemos
    planemos Toyotaholic
    British Columbia
    There was a guy who was getting the adapters made at a machine shop a while ago. The kit was using 4 runner 4 piston calipers (V6). And wilwood rotors and hats. The guy claimed that you would be able to lock up the front wheels at any speed. I went this route but haven't installed them yet. Try searching big brake upgrade. I don't think you can get the caliper adapters anymore but all you need is the proper nuts and you can mock up some and get a machine shope to make you some.
  3. chrisyou
    chrisyou Member
    Bay Area, CA.
    1993 2wd std. cab
  4. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    you need to get those adapters and make some more before you instal them
  5. Kay_XRS
    Kay_XRS Newbie
    Pomona, CA
    Is anyone still selling/making these 4runner caliper bracket for the 1/2 ton p/u trucks
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I got a set of those brackets & run that kit.
    The kit from Revolution is a great kit & I was going to use that @ first. They have the rotor & hat as one piece as the stock Toyota rotor.
    The set up I run ,a Wilwood drilled /slotted 12.9" rotors ,Wilwood hats ,Wilwood bolt kits ,Toyota 4 Runner 4-piston calipers, & the brackets from the guy on this site,( he may still have some ,or be running another batch), all come to around the same price as the Revolution kit, $700 +
    Either way you'll have brakes that work great ,look great & increased stopping power!:cool:
    yotaman95 likes this.
