Brake booster delete project
Discussion in '1976-1983 Build-Up/Project Threads' started by Toyotashack, Jan 1, 2022.
  1. Toyotashack
    Toyotashack Enthusiast
    Monroe, WA
    77 hilux 92 2wd 89&90 runners
    77 pickup.. making more room for turbo.
  2. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Need to pick up a rivnut tool kit. It's so you can run a bolt through a blind hole.
    TRUCK ACTION likes this.
  3. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    As much as I love and use rivnuts for various cover plates and light duty brackets, I wouldn't use them for this application. Even if you use structural quality rivnuts, there is so little supporting sheet metal.
    I would get some 1/2 inch steel plate and bolt it to the firewall. Then drill and tap mounting holes for the master cylinder mount in the 1/2 plate.
  4. jetas
    Or 1/8" with bolt heads welded on the backside
    Perkolator likes this.
  5. MrDinkleman
    MrDinkleman Addict
    SoCal
    Oh. Just thought of a possible quicker solution. Make the master cylinder mount plate by cutting it out of the front of the booster (assuming op still has the booster and is really ready to trash it...)?
    Perkolator and jetas like this.
  6. Toyotashack
    Monroe, WA
  7. Toyotashack
    Monroe, WA
    Trimmed the master so the bolts would clear.
    Also made my rod from pedal to master from an old clutch master rod. Extended 1.25" to a perfect fit.
  8. Toyotashack
    Monroe, WA
    Blasted and anodized the brake booster delete plate. Zinc plated some bolts for it too.
    That frankenbolt is the rod from pedal to master. It is now painted black and installed.
  9. Toyotashack
    Monroe, WA
    There it is.
