Body Swap
Discussion in 'Exterior/Body' started by maceycd, Mar 8, 2011.
  1. maceycd
    maceycd Newbie
    Colorado Springs
    88 standard shot bed
    I have a 1988 toyota pickup EFI, but it just got totaled and now I found a 1987 4runner with a bad motor also EFI. I wanted to know what your thoughts are on swaping the bodies. I can get the 4runner for 500. The major difference is 4runner is manual and the truck is auto with shifter on the column. I thought it would be cool and I know it has been done before. The reason the truck was totaled was because of a hit and run on the bed nothing really bad. Also the trucks body is just ****. Huge dent on the passenger side and tweaked core support. Let me know what you think, good or bad.
  2. jetas
    Just swap the motor into the 4runner.
  3. Dogfather
    Dogfather Veteran
    Rochester, Washington
    1976 Toyota hilux & 77 Toyota Pickup
    if you do a search on here for the word runner you will find a couple build threads where they put a 4runner on 2 WD frames
  4. maceycd
    maceycd Newbie
    Colorado Springs
    I would swap the motor if I want a 4wd runner, but I dont I like my lowered truck. I have seen one build thread with a second gen runner swap. I have seen picture of the swap I am talking about but no build threads on here. What do you all think about the amount of work. I know the frames are the same length but are the body mounting points in the same spot. The trans linkage I think I would just go to the junkyard and get one out of an auto and cover up the transfer shifter spot.
  5. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    You have 3 options, fix the wrecked toyota pickup, buy a new toyota pickup and dont worry about the 4runner or buy the 4runner and put the motor out of your pickup in there. My opinion is to get a new pickup and use the wrecked one for parts.
