Blinker mod?
Discussion in 'Exterior/Body' started by yota4life, Feb 11, 2011.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    What do you guys think of an LED strip as a front blinker? AVS sells 4.5" LED light and I was thinking of getting 2 of them an mounting them in the front bumper (I have a smoothie bumper and there's nowhere for a blinker) do you guys think it would look good
  2. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Do it. Im using a 49" led light bar for my tails,runners,blinkers,reverse in the rear and carbon crotchrocket signals in the front. I might even drop those and get the led's for the front since you mentioned it.
  3. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    They're 45 a piece but I think thts really cheap for some LEDs I think it'd look clean an simple
  4. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Idk something I've never seen before
  6. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Plus I'm gonna shave my corners
  7. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    i dont think they'll be bright enough..i made my own for bout $20 for both, and they are way brighter than what your looking at, check my build thread i think i have em in there...i'll post a video so you can see
  8. joeynational
    PHX,AZ
    91 2WD
    here is some videos of mine that i made
  9. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I can't see those videos. But I don't think it'd be to bad using thoughs especially at night
  10. IronNam
    I put my signals and parking lights both into my corner lights.
  11. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I'm gonna shave my corners eventually and do a headlight conversion so i just thought using the little 4.5" LED would be sik an different
  12. eurofreak2002
    B-town 208
    Yes it would be sick. Do it before I beat you to it.
  13. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I am my birthday is next week hopefully I get some $$ and I'll buy them. I'm thinkin amber LED with clear lens or red LED with clear lens
  14. IronNam
    amber. red would cause legality issues.
  15. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ya thts what i thought too plus it'll give it a stock but custom look
  16. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
  17. joeynational
    PHX,AZ
    91 2WD
    yeah it would probably take a small circuit with an inverter chip and a relay..the inverter chip wont supply enough voltage to the corner, hence the reason for the relay..Or you could possibly use an Op-amp to boost the voltage..
  18. IronNam
    I already have my corner lights do the parking and turn signals.
    Neighbor down the street has a friend with a flat black lifted 4Runner 92-95 with an LED strip under the headlight and it stretches across under the corner lights. I think it looks neat. one LED strip per side.
