Best price/performance clutch kit?
Discussion in 'Off Topic' started by first80toyota, Feb 21, 2014.
  1. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    I'm looking for a clutch kit for when I swap motors.. Hopefully not too long from now!
    I'm looking for a good setup that can take the occasional light to light race (stupid civics need to be shown:waytogo:) but I don't want to spend a lotttt of money...
    I'm open to suggestions!
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    A heavy clutch set up runs around $300& I'd go with a light height flywheel @ the same time ,around the same!
    I'm very partial to LC's products!! :cool:
  3. first80toyota
    Pacific Northwest
    '77 Hilux
    I had my flywheel lightened already..
    What do you mean by a heavy clutch? Like heavy duty or is it weight heavy? I'm guessing heavy duty..
  4. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Yeah, heavy duty...
    They're usually rated in stages.
    Stage 1: mild performance, daily driver status
    Stage 2: medium performance, might suck in traffic?
    Stage 3: heavy performance, mainly for racing, grabs hard, would suck to daily drive
  5. first80toyota
    Pacific Northwest
    '77 Hilux
    Does anyone know how to determine what size clutch I need for my flywheel? I don't know what year it's off but it's going on a late 22r block.. They have one size for 81-88 and a different size for 89-95.. Are they interchangeable? If not how do I measure to figure it out?
  6. first80toyota
    Pacific Northwest
    '77 Hilux
    I figured it out, the center ring on the flywheel is only 9 inches in diameter so a 9.25 inch clutch ain't gonna work :waytogo:
  7. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    i got me the "PRO" clutch kit from lce as well as the lightweight flywheel. it handles fine. truck is driven daily. very happy with the product.
    $0.02
  8. first80toyota
    Pacific Northwest
    '77 Hilux
    How much stiffer is your clutch pedal?
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Have the same,very daily friendly!:cool:
  10. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    Act here but I got the 6 puck sprung one
    it does a good job pedal feels stock to me
    but buying a 22rte will do you just fine in less you plan to install some big power adders turbo ect
    lce clutch are just re-branded junk they use cheap disks
    I have scene these type fail so many times from the spring popping out the spring pocket are drilled them bent to hold the spring in
    Nore do I like center force there weight system is just added weight that is just plain not needed plus there not the most smoothest clutch again because of the weights.
    If ya get centerforce with out weight there good and they use high quilty disc's just like act
  11. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    feels like stock. maybe a touch more sensitive, requires little bit more pressure but more accurate feel -if that makes sense. but i guess it basically feels like a new stock clutch :confused: just more holding power.
    :waytogo:
    it holds up fine. used and abused mine is. dragging at the strip, street racing, and daily driver. its been almost a year now of constant abuse. holding up fine.
