Best fitting front fenders?
Discussion in 'Exterior/Body' started by Blacklightnin55, Jan 8, 2012.
  1. Blacklightnin55
    Blacklightnin55 Member
    Louisiana
    1990 Ext-cab
    I have a 1990 Ext. Cab Pickup. Swapped a 7MGTE into it about 5 years ago. Did the 4 runner front end
    change using some aftermarket fenders which I purchased off EBay. I do not like the way they fit. They look like crap. I want better fitting fenders. Does anyone know where I can get some good quality fenders? Will I have to go to the Dealer?
  2. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    go to a wrecking yard and find runner or 4x4 oem fenders....thats gonna b your best fit.
    afterpop fenders are hit and miss with fitment!!:rolleyes2:
  3. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Yah if you cant find used OEM then Kappa (Cappa) Certified would be another route as they are aftermarket but so close to OEM fitment you pay slightly less for them. Full on Aftermarket is garbage I learned the hard way as well. If none of those work then yah dealership but be prepared I think last time I look they were almost $240 per side factory OEM. Clean ones from a junkyard can run $25-$75 Kappa cert will run about $120-$165 per side depending on who is selling them.
