Bent axle shaft... ?
Discussion in 'Engine/Drivetrain' started by Litneon, Jun 1, 2009.
  1. Litneon
    Cocoa, FL
    94 xtra cab
    Has anyone ever bent a shaft in your 7.5" housing? I have developed a bothersome vibration over the last year and have been chasing it everywhere, it seems to be coming from the rear of the truck.
    I started by replacing the driveshaft support bearing (even though I knew that the vibration isn't a driveshaft one...), followed by having all of the wheel tire combos "road force" balanced (amazing technology).
    I found one bad tire, replaced it, and the problem is still there. It feels like a wheel balance issue, but have had the full set balanced more than once, ruled that out. I rode in the bed one day while a friend drove, didn't see any tire bounce or signs of a tire out of round.
    Finally, tonight I jacked up the rear, put jack stands under the frame to let the axle hang out and started her up. I noticed that on the rear passenger side the whole wheel and tire are slightly out of whack. Just a few thousands runout (guestimating). Since the road force balancing detects wheels that are bent and or out of round, I ruled the wheel out.
    So, this leads me to believe one of a few possibilities.
    1.Bent axle shaft.
    2.Bad brake drum?
    3.Bad bearing install. (I changed these quite a while ago.)
    Thoughts?
  2. Nook
    Nook Addict
    oregon
    I think I would check out the Ujoints and the rear wheel bearings, not likely you bent an axle shaft unless it took a good hard hit and bent the housing too.
  3. stll2hi
    stll2hi Member
    Temecula, SoCal
    92 xcab & 98 Taco
    Got the same sorta thing on my 92 and it is the u joint right where the drive shaft meets the rear housing...I'd start there. Mine rattles like crazy sometimes...feels like you're almost starting in 2nd gear it rattles so bad.
  4. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    ditto
    but it more sounds like a bad bearing to me.
    have you tried shaking the wheel by had to check for play up/down/side/in/out?
    on my wheeler i chased death wobbles for ever, replacing every bearing and buying all kinds of special tools to setup the axl.
    turns out i had a bad bushing in the leaf
  5. Litneon
    Cocoa, FL
    94 xtra cab
    I've had U-joint issues before in my 4Runner, it doesn't resemble that at all, and I already checked those.
    I'll check the bearing and leaf bushings next.
    Thanks.
