Beltech sway bar
Discussion in 'Suspension/Chassis' started by yotaman95, May 5, 2013.
  1. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    So i bought the suspension package and sway bar kit from beltech. I got the rear end done but the front is causing me a little trouble. I got the old sway bar out but now the new one wont fit! What do i have to take out to get this out and how do I do it? Any help would be fantastic!:waytogo:
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Is it an issue of the new ones shape? Or is the diameter too large for the stock mounts? Any pics would help us help you.
  3. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    Yes, Please do show! I am about to order this part next week.
  4. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    About 25 years ago, I replaced my front sway bar and added a rear one. I also had trouble installing the front bar. I believe that once I got it on the rack & able to mount the center brackets, we had to pull down the sides using body weight.
    Hope this helps!
    Rick
  5. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    I never had an issues the rear bar did not fit well, **** driling a hole in the frame plus the gas tank was in the way
  6. yotaman95
    1995 single cab
    Its that is bigger and the curves are way more abrupt, any way i try to slide it past the torsion bars it hits the oil pan. I know i am suppose to take the torsions out but i got the old sway bar out without having to drop them just cant fit the new one in! :/
  7. standardbyker88
    lynnwood, wa
    Undo the motor mounts and raise it an inch or two. Might be enough wiggle room. A lot easier than undoing a torsion bar. Motor mounts are easy, 4 nut and bolts sandwiching 2 layers together. Can probably get 3" before the trans hits the tunnel.
  8. NashMan
    NashMan Toyotaholic
    94 2wd
    you have to remove one bar and it will fit
    Not to hard at all, just mesher before taking it off
  9. yotaman95
    1995 single cab
    Success!
  10. topcop182
    topcop182 Addict
    1993 single cab 2wd
    Linking this for when I do this! HIGH FIVE
  11. yotaman95
    1995 single cab
    Hey dudes where is a good place to find drop upper and lower control arms? And will it drop my front end?
