What's up guys been awhile since I posted anything on here been busy working an working on the ladies new car its an Integra lowered on coilovers. But we went to smog it yesterday an it failed trying to figure out why I'm thinking its the cat cuz it only failed at 15mph. Anyone ever have one of these cars before? Since u guys love pics ill post some. Before with messed up fender New fender New fender an hatch struts
Clean car.mi would check the cat and the O2. Sounds the cat is not warming up in time to burn off the fuel. Can you post up the number readings as that will help.
can you post the numbers for the failed smog, im a mechanic I could help figure it out if i had the numbers.
I talked with my brother his car had a bad o2 but it through a check engine light which this car isn't. I'm guessing its the cat aswell. I got a buddy tht said I can use his to pass smog. But I wanted to.make sure it was tht first
I've had five motor swapped Hondas , do you have any check engine lights just because you dont have a light doesnt mean doing the jumper wire test wont find it seen it a few times Hondas like to eat rear o2 sensors on cheap gas . Also check to see if the cat has been smashed or dented up . From being to low the honey comb breaks up and makes an exit .
Ill get a new o2 sensor just to be sure. But I haven't got under it to really check how bad the cat is. Don't have my Jack here but I'm sure its probably dented up.
Hondas are pretty good cars my buddies is at my house right now it's a 95 Honda civic ex with a greddy turbo kit . And the worst nitrous install I have ever seen as well as wiring gonna straighten it out for him ... I got pics if u guys wanna see a rats nest of wires but yea def check the 02 and cat .maybe give it a little tune up before the next test
