Bed
Discussion in 'Exterior/Body' started by DJ63, Sep 8, 2014.
  1. DJ63
    DJ63 Newbie
    Albuquerque, NM
    Hi guys, I’m just starting out with the Toyotas and have a question. Is the 4x4 bed the same as the 2wd bed for a 94 toy? I have 4x4 fenders that I plan on putting on and those are obviously different. Also what years will interchange with a 94? Thanks in advance.
    DJ
  2. jetas
    89-94 beds are all the same. I think even the ex-cab bed is the same.
  3. DJ63
    DJ63 Newbie
    Albuquerque, NM
    Really, so only the fenders are different from the 4x4 to the 2wd?
  4. jetas
    Fenders and corner lights. You can do almost any combo of 2wd, 4x4 and 4Runner front ends.
    Some combos have odd gaps tho.
  5. silverblazer50
    silverblazer50 Enthusiast
    Thomasville GA
    1994 reg cab
    If you want wider rear fenders, there are two bolts that hold the bed side on in the fender well. Take the two bolts out, and push the fenders out to the other bolt holes. You must take the fender liners out to do this.
  6. Tricky03
    Tricky03 Member
    Bend, OR
    '93 std cab, 2wd, short bed, 22re, 5spd
    Do you have any photos references for this mod?
