Bed removal question
Discussion in 'Exterior/Body' started by 22R88, Mar 28, 2012.
  1. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    I am in the process of removing the bed to clean and undercoat it. When I go back is there any upgrade type mounts (rubber cushion or bushing ) as opposed to the old dried out ones that are on there now. I have it ready to lift and so far I have only lost one of the double nuts so i guess I am doing pretty good. any other ideas or tips appreciated
    22R88
  2. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Seems uneccisary to replace them to me.:shrug:
  3. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    The factory ones should be fine
  4. 22R88
    22R88 Veteran
    South Louisiana
    OK thanks
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Energy Suspension has poly cab & bed mounts if you want to replace them!:cool:
  6. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    1983 Toyota SR54x4 Mojave Edition-Black Package Shortbed Sport Truck
    I agree with TRUCK ACTION. Replace the bed mounts with Energy Suspension items if you are going to keep the truck. Mine have been on for 25+ years and still look new.
  7. ffryno13247
    ffryno13247 Member
    I used a mud flap from NAPA and cut it in to small rectangles to re place the th little rubber pads on the bed
  8. raylcc
    raylcc Addict
    Denver, CO
    Are these the ones you were talking about?
    Energy Suspension 8.4103 Body - Frame Mount Bushings
    I couldn't find them for the 2wd. Are the 2x4 and 4x4 mounts the same?
