Bearing Questions 22R-E
Discussion in 'Engine/Drivetrain' started by Relyks13, Nov 30, 2014.
  1. Relyks13
    Relyks13 Newbie
    I have .25 bearings on a re-manufactured crank and I seem to have rod knock.
    ( which sucks cause i only put 1200 miles on this motor and crank after it being rebuilt at a local machine shop, but when i pulled the rod cap bolts they were not on tight at all :confused:thank god no damage was done of course i parked it after the knock began )
    So I plastigaged it .0015 all the 4 cyclinders and my question is what is the clearance suppose to be and what size do i got to now?
    i was planning to call LCE engineering in the morning and order them right away so any feedback and questions will help before i talk to them tomorrow.
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    What are you measuring in. Inches or mm? Max clearance is .08mm. Or .0031 inch
  3. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    If your just getting new bearings use the same size it had, especially if your clearance was .0015"
  4. Litneon
    Cocoa, FL
    94 xtra cab
    Do you know that it was rod knock? If so, how?
  5. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    did u oversize the rod bearings or the main bearings or both?
