Battery and brake light on while driving
Discussion in 'Maintenance/Repair' started by NY_83_4x4, Feb 14, 2011.
  1. NY_83_4x4
    NY_83_4x4 Newbie
    83 4x4 long bed, 74 Celica
    Hi. I have an 83 4x4. Recently the the battery and brake warning lights have been staying on after starting the truck and while driving. Has anyone else had this problem before? I checked the fuses and they were all ok. Not sure if it is a fusible link, voltage regulator, the discharge light relay or a short in the wire. My thought is a short since the brake warning light is on as well. Any help is appreciated before I begin looking for a short. Thanks.
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Your charging system has failed. The brake & battery light isn't a short thats how the truck tells you its not being charged.
  3. jetas
    Is it struggling to turn over wen u start it??
  4. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Im 99% sure its just the alternator. Take it off and have it checked to see if its charging.
  5. NY_83_4x4
    NY_83_4x4 Newbie
    Thanks for the replies. It is in fact the alternator. I have ordered a new one.
    A friend told me a good check is to tap it with a hammer and you will here the engine noise change as it picks up the load of the alternator and the lights will turn off. That is exactly what happened.
