Basic performance?
Discussion in 'Engine/Drivetrain' started by -85yota, May 10, 2013.
  1. -85yota
    -85yota Member
    What are basic performance parts to do to a 22r efi?
  2. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    Cold air intake, exhaust, header, under drive pulley's, cam, l could be missing some thing's,
  3. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    step one: Google.com
  4. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    swap crank fan for electric fan.
  5. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    check out my build thread in the 89 section
  6. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    gasket matching and porting the intake manifold will help alot on throttle response and mid range power too. larger throttle body and AFM are other small gains but important if you plan the bigger power adders like a full exhaust or moreso a cam swap. most the mods are fairy cheap and easy to do.
    more in depth would be removing EGR, smog pump, emissions parts, running a late style intake manifold if you have the old type. easy way to tell is throttle body angle. bent down is old, straight out is new. new has a better flow path and gains a few extra. if i was going to port an intake, id use that kind and swap over. less down time the day of engine work too if you port a 2nd part. hope this helps.
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    LC Engineering ,stage #1 Pro Street EFI!
    Have been running this for 6 or so years now,only 24,000 on engine, great performance ,runs fast & hard!!
    Just drove my truck 220 miles to a show & back,cruising @ 70-80 all the way!!
    Love it!!!!:cool:
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Flux capacitor ... Don't exceed 80mph
  9. Turbo Blow Through
    Turbo Blow Through Addict
    austin tx
    87 hilux
    Pulse jet!!!!....jk.
  10. jctoy29
    jctoy29 Addict
    surprise,az
    Nos!!! And overnight parts from Japan. Jk..
  11. Turbo Blow Through
    austin tx
    87 hilux
    Hey a 75 shot of a wet kit makes these things a beast for sure. U can piss alit of people off when you walk them on steal wheels and body rust......lmfao
  12. -85yota
    -85yota Member
    Where to get nos LCE...???
  13. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Nos can be had at jegs.com or summit.com... I wouldn't go that far yet spraying is a large step up .
    I'd start with the things mentioned header cam carb upgrade exhaust . Ignition system clutch and flywheel
    If you do buy a kit get a wet kit fuel/nos combo
  14. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    I wouldn't jump into NOS right away.You will need to upgrade your internals before you start popping NOS or else something will eventually give.Start with the basics like a cam,dual springs,flywheel,clutch etc..
  15. -85yota
    -85yota Member
    Whats a good cam for it im getting headers in a month or soo straight pipe it! But for the cam will i need to mess with the computer or no...??? Thats what kinda confuses me
  16. Turbo Blow Through
    austin tx
    87 hilux
    Yea I was just kidding about the spray don't pop you motor spray is only short term fun nothing last long on spray
  17. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Correct---on juice just kills an engine ,any engine!!
    Build a strong engine or buy a built engine---LC is a very,very good way to go!!
    This will not be cheap ---quality parts & building cost $$$$$$$
    but like the old saying goes,you get what you pay for!!:cool:
  18. Cooter
    Cooter Newbie
    Virgin-ia
    1994 Reg cab 22RE, 5-speed
    Actually, Nitrous Oxide is no more Deadly to an engine than Upgrade Performance cams, intakes, T-bodies, etc. When used in moderation. The problem with Nitrous is it isn't "Stupid proof", as the user MUST read plugs, and stay away from the "OMG! if 75 HP is good, then 400 shot MUST be better!" type thinking. Sooner or later, you will pop it. I've been spraying my cars for 20 years and never blown a head gasket.
  19. Malessohomegrown
    Malesso,Guam
    I believe a good 22re cam would be in between the 270-280 duration but you should talk to the techs a LC and let them know what you want to do and they will guide you in the right direction.We ran a 280 Web cam in my bro-in-laws truck and it was good with no disruptions to the computer.
  20. Turbo Blow Through
    austin tx
    87 hilux
    True with moderation and knowledge things can stand the test of time I've had both spray and boost and spray can give you that competitive edge as long as you don't over do it.
