bagged and bodied toyota..motor hitting hood.
Discussion in 'Exterior/Body' started by lowclassyota, Mar 18, 2012.
  1. lowclassyota
    lowclassyota Member
    greensboro NC
    1994 Toyota pickup bagged and bodied 5"
    i need help with the the hood on my truck. its bagged and body dropped 5 inches. and my motor stick out of my hood. and i cant seem to find a cowl hood. or a raised hood. any help or suggestions would be great
  2. Zombie Monarch
    Zombie Monarch Veteran
    Springfield, MO
    1991 single cab dually hilux
    Thought about buying one and fiberglassing it on?
  3. lowclassyota
    lowclassyota Member
    greensboro NC
    i thought about getting a stock hood. cutting it in the center and folding the sides up and weld in some sheet metal an make my own cowl hood.. but i dont know how successful i would be lol.
  4. Zombie Monarch
    Springfield, MO
    I think it would be easier to just by one of these "glue" on cowls, you can obviously attach it different than with just glue, then fiberglass it smooth.
    Auto Parts
  5. lowclassyota
    lowclassyota Member
    greensboro NC
    i dont think those are wide enough for my truck.. and is seeming to be my problem.
  6. Zombie Monarch
    Springfield, MO
    Toyota
    Found this site that sells bolt on cowl hoods. How wide is the hole you need filled in the hood?
  7. lowclassyota
    lowclassyota Member
    greensboro NC
    i need to go measure it. ive been looking at some.. when i dropped my truck i just cut a square in my hood. without really thinking about it as my hood was messed up anyways. and i saw that site also. i found a hood scoop i think will work.. but asfar as my current hood and the big hole its going to be some work getting it to work. may be better off just buying a hood.
  8. NotAvailable
    NotAvailable Addict
    ask seth. TWISTED MINIS. he sells motor drop mounts and shortened oil pans for our trucks.
  9. lowclassyota
    lowclassyota Member
    greensboro NC
    do you currently have them installed?
  10. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    a 5" bodydrop is pretty much laying door right?
    i don't think any pre made cowl hood will bolt on being that low. you'd probably still need to lower the motor, section the pan, and modify the steering to get it to fit a bolt on.
    you could always get a custom intake built and a shaved valve cover (on top of everything above) to clear a stock hood.
  11. NotAvailable
    NotAvailable Addict
    no. i was only bodied to the rockers. never had to deal with clearance issues with my motor and i owned a 22r not 22re so idk which ones taller. good luck. also visit seths site. twistedminis.com hes super cool and straight forward.
  12. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    I agree overall this is the best solution, my truck is bagged and bodied too and lays flat frame and rocker and my motor was lowered, oil pan sectioned and steering modified, I still retain my stock hood with no hole and have had no problems.
  13. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    How much does the motor stick out?? Maybe hood spacers would a quick solution.
  14. lowclassyota
    lowclassyota Member
    greensboro NC
    im pretty much laying doors maybe 1/4 an inch from the ground and i found some cowl hood scoops that i can mold to my hood that just might work.. and my motor sticks up and good 3 inches slammed.. so lowering the motor will only help a little..
    as i stated above the the other guy my motor sticks out of the hood a good 3 inches.. so his 1 inch lowering mounts wont really do me much justice..
  15. low_toyota92
    low_toyota92 Enthusiast
    Nashville, N.C.
    92 ex cab
    sorry for being off topic, but did you just buy this truck, or where you trying to sell it... i just seen it on craigslist and was thinking bout checking it out jsut to cruise on till i finish mine....
  16. lowclassyota
    lowclassyota Member
    greensboro NC
    a good 3 inches
  17. lowclassyota
    lowclassyota Member
    greensboro NC
    i actully bought it. i sold my s10 that was bagged and bought this one..
  18. low_toyota92
    Nashville, N.C.
    92 ex cab
    Cool. so you live in NC?
  19. lowclassyota
    lowclassyota Member
    greensboro NC
    yeah i live in greensboro and my brother has a bagged and bodied s10 with a 350.. he lives in jacksonville and is the marines but has his own shop/garage where he build trucks either for himself or friends..when i get this truck ready for the road i need some cruisin buddys.
  20. macawilial
    macawilial Veteran
    Born and raised in San Diego
    I went with a custom hood.
    I bought a steel cowl for an S10 off of rollpans.com(?) for like 80 bucks and had it split down the middle to widen it so it matched up with the lines. Had it welded up (I suck at sheet metal). My total cost was around 180 bucks for the steel cowl and labor.
    Check my build thread for photos.
    Hope that helps
