how do i tell if i have a bad coil?... my truck turns over and i can smell gas coming out of the carb. and i even tried some started fluid but i am getting no fire out of it... thanks
locate a friend to help, take the coil wire off the dizzy, if its a male end that sticks out a little hold it very close to a ground point, but leaving a little air space like 1mm. a bolt on the valve cover or some other metal part of the motor like a bracket, get your friend to try to start the motor, you should see it sparking fairly bright. if you do its not the coil, and plug that back into the dizzy, if not it still may not be the coil but the ignitor, points if you have them, the distributor eletronics could have gone bad ect. so dont go tossing a coil just becouise of no spark. some autoparts stores have a book behind the counter that shows how to test coils with a muti meter, unless a member can chime in, anyhow ask your local store if they can test your coil if so bring it up to them. if you have spark and still no start, do the same thing but with a spark plug wire, it should spark 1/4 as often but just about as bright, if you have spark then. check your plugs, could be done, if you havent changed them in a wile it wouldnt be a bad idea to just pick up a new set anyhow same for cap and rotor if it hasnt been recent. im sure i missed some stuff but that will get you started.
Then perhaps he should tell us more... like the year and type of engine hes got. Not going to be able to provide any specs for him otherwise.
ive told him this a bunch of times now..im kinda refusing to help until he puts specs somewhere where i can find em on his posts.... its probably his headlights that are stopping his motor from starting.
it says what year it is in my info right next to my post...look next time...its a 22r...and i tried putting the wire to a ground point and no start...i done the volt meter to the connectors where it has power and it says 13.46 and i done it where the plug wire goes into it..and it said like 0.34 i appreciate the help because my truck has been down for like a week now...
the coil is good, they hardly go out on those motors...its the ignitor...like usual with those motors....150ish from a junkyard. i got mine for 50 bucks off craigslist from AZ, guy shipped it. good luck
something stupid I did, check the wire that conects the distributor. I left mine unhooked and wasted a day trying to correct the problem.
thanks guys...the ignitors at junkyards here at like 16 bucks....but does the v6 model pickups have the same ignitor and coil as the 22r?
no the ignitor is different then the coil, and the msd blaster 2 i think is a coil. if your junk yard sells em for 16 bucks buy em all and sell em here in socal, they are 150 here
well i went yesterday and someone has got them all....but all else fails ill sell the toyota and buy the next year up or something...but def keep it toyota
