back right rim rubs when the truck turns
Discussion in 'Suspension/Chassis' started by ToxicToyz, Nov 10, 2010.
  1. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    The back passenger tire on my 88 is a little closer to the frame than the other side.The rim rubs on the frame only when the passenger side of the truck drops.Do you guys know what might be causing the problem and how do i fix it?
  2. IronNam
    is your leaf bushings worn? could be making the suspension slop to the side.
  3. oldschool64bus
    oldschool64bus Veteran
    Boise, Idaho
    1983 SR5 4x4
    U bolts loose? bad lowering blocks? maybe the bushings like Cin said. can you get some pics up?
  4. Litneon
    Cocoa, FL
    94 xtra cab
    From your tiny avatar pic, it looks like you are running the normal 42mm offset wheel, maybe an 18" x 7.5"?
    If so, there isn't quite enough room between the wheel and the frame rail when the axle moves around. There isn't much you can do about it except maybe some small spacers. If you go too far though, you run the risk of rubbing on the fender.
  5. IronNam
    he may have to roll the fender lip a hair.
  6. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
  7. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    the bushings on the shackles are a little cracked too
  8. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i'd start by replacing the leaf bushings. they are only like $6 a piece from toyota. probably cheaper for aftermarket.
    or get some energy suspension bushings for a nice upgrade.
  9. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
