b/j flip problem
Discussion in 'Suspension/Chassis' started by 73TRD, Feb 19, 2010.
  1. 73TRD
    73TRD Veteran
    Redding, CA
    84 sr5 standard cab short bed, 73 hilux short bed
    my friend has a 92 pickup with manual steering. he did the ball joint flip and the other day a bolt got caught on the lower control arm and locked his steering. he freed it up, but i was wondering if anyone has had a similar problem
  2. planemos
    planemos Toyotaholic
    British Columbia
    I've heard of rim clearance issues with BJ bolts but never with steering. Do you know which bolt it was?
  3. Beefed Taco
    Beefed Taco Addict
    Is he running hardware that has a bunch of extra threads sticking out or something?
  4. IronNam
    Did he do it right?
  5. 73TRD
    73TRD Veteran
    Redding, CA
    i'll have to take a pickture. the bolt that got caught doesnt look like it goes to anything. its just threaded in a hole:shrug:
  6. 73TRD
    73TRD Veteran
    Redding, CA
    i took another look today and the bolt was a stopper for the steering so you dont bend the backing plate. we ran it all the way in and its good now
  7. IronNam
    ahhhhhhhh OKAY. I see what you're talking about now. Its that bolt that "limits" the steering right? yeah, it can do that if you crank it far and hard enough... it'll catch. mine did that but came off. least its working right? mine's actually worn, on the cap part. need to replace it with something "new"
  8. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    knew exactly what it was soon as you described the issue..... :lol:
    however, you should not run the bolts all the way down to unlimit the steering.... the reason for limiting the steering is it WILL give you more steering angle but you also run the risk of over-stretching the rubber brake lines and possibly popping them free...... this would be bad so........ check and make sure that at full lock it has no tension on the lines. even if it has a little tension the steering still has more give when moving so this will give even further stress to the lines.
  9. 73TRD
    73TRD Veteran
    Redding, CA
    will do. thanks
  10. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    and id imagine a larger rim diameter or the wheels not being so wide would help. spacers or less offset.
  11. 73TRD
    73TRD Veteran
    Redding, CA
    the wheels werent touching. turns out the lower b/j loosened up. i told him to check it like a week ago. its all good now. and he just picked up a set of maxima 6 spoke (the round spokes) 17's for $50. we're gonna paint them like mine
