autopal headlamps
Discussion in 'Interior/Electronics' started by ToxicToyz, Jan 27, 2011.
  1. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
  2. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Do you need a wiring kit if you use halogen bulbs??
  3. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    i've read those lamps are pretty good, i've also read that the output is better on the flutted lens(not the clears)..I would buy em. I'd throw in some Phillips xtreme power X-treme Power and you can make your own relay harness or just buy one, here is a link if you wanted to make your own
    Headlight Loom upgrade
    you dont need one but it does help, especially on our older trucks
  4. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    What wound happen i if you don't use a relay harness??
  5. joeynational
    PHX,AZ
    91 2WD
    nothing..it gives you more power to your lights, which will give you slightly better output, check the link you can see the difference.
  6. joeynational
    PHX,AZ
    91 2WD
    if i was still running halogens I would use one, they are cheap and worth it, also cheap insurance, my truck is 20 years old, which means the wiring is too
  7. joeynational
    PHX,AZ
    91 2WD
    but this is what you don't want
    you want the full harness
  8. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    how safe is buying stuff from ebay.Has anyone bought these lights before from ebay??
  9. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    that pre-made harness is pretty schweet, where did you find that?
  10. joeynational
    PHX,AZ
    91 2WD
    what you never bought anything from ebay:eek:?! well its been around for a long time so i'd say your safe:waytogo: stick to sellers with lots of good feedback and you'll be fine
    it came from some offroad website, first thing that came up when i googled it
